1 - 8 of 8 Posts
single plate bracket? I can get the 553 on by bumping it over the pulley (8/3) but I can't get the tensioner pulley on (i have the dual plate brackets)
I have the dual plate brackets, but mine is also driver-side so there may be a spacing difference between the two. I am using the 6" tensioner pulley as well.
i have the passenger side. not sure what size tensioner pulley i have but its the one that came with the kit. i did purchase a very large one years ago but it won't clear the bracket bolt heads without some milling. never got around to it
I have the passenger side set up with my Ysi with the renegade brackets. (Double plate 4" idler pulley) My upper is 2.800 and the lower is an 8" The correct belt part number for the FleetRunner is: K080560HD.
1 - 8 of 8 Posts
