1 - 8 of 8 Posts
We need to get a new drive shaft made for our 86gt drag car it now has a g-force trans and the drive shaft needs to be longer should we lose the flange set up and just go with a reg forged yoke on the rear?
I have the Strange one. It is very nicely made.
thanks guys
There are flat forged pinion flanges as strong as any U-bolt saddle flange.
I went with a forged dual pattern from a local driveline shop that accepts either the stock Mustang size joint or the truck size joint. It is a real nice heavy duty piece.
Ford makes one for trucks PN DL3Z-4851-A but it is large pattern only.
The mark williams yoke comes set up to have a driveshaft sensor installed if you want to measure driveshaft RPM.
1 - 8 of 8 Posts
