Just got the car back together and finally got her out to make a hit with what I knew was a very poor set up but wanted to get it on the track and start to get real life data the set up in the car for the video is
371
AFR 205
10.5:1
Solid Roller cam
Pro Systems HP 750
Power glide (3k stall, YUCK!)
4.30s
As you can see the car just pukes as I was told the stall was a 3800-4k and must of been that behind a pretty torque driven motor as it only stalls to 3k for me, But now that I got this pass out of the way and have some data only place to go is up!
Up Next
6300 Stall
Pro System HP950
Should wake her up!
Hey, the MPH is pretty damn good - the best I could muster NA with my glide and converter setup for the Whipple was 117 mph; I could barely crack 11's.
What brand/size converter do you have now?
FWIW - these things are slugs with a 3,000 stall converter - here's an in-car of mine. Prepare to be bored:
