81 - 81 of 81 Posts
Discussion Starter #81
if you have a fuel pressure sensor, you must turn on "enable". this is located where you adjust the low slope.
if its enabled, and you are not running the fuel pressure sensor, it will cause you problems. it must be disabled if you're not running the fuel pressure sensor.
Just double checked and it’s setting is disabled, or not present and it’s listed on here.
81 - 81 of 81 Posts
