1 - 20 of 20 Posts
I compare your times with mine. you went 11.35 @ 117 with a 1.54 60 ft and I went 11.24 @122.37 1.53 60 ft. Weird mph thing we have...lol
If you have a after market cam it dont count as STOCK
Wow.. Stock block, bore, stroke, displacement, and rotating assembly, then?
Enough to impress you? :blam:
**Edited my original post with fine print for further clarification
thats awesome! im hopeing for mid 12's with my stockish motor. Just enough to convert it to carb is about the max for motor mods
I went 11.17 @ 119 With the factory 4.6L
Everything in the motor is stock including the Cams.. :)
What i think is more challenging is taking real street tires into the 11's N/A.. i went 12.07 last nite after working out the bugs & im pretty sure now that ive screwed the street tires to my stock wheels she'll go 11's.. Especially now that i know the setup required when i arrive instead of totally missing the setup like last nite! :)
These are real street tires.. Not Drag Radials.. Not really good Nitto's either.. Just a plain jane cheapie Raptor radial tire, ive nicknamed the Crappers! :king:
I went 7.19 @ 94.7 with a 1.54 60ft. N/a stock 302 bottom end, a.o.d. , 2,800lb. coupe. Runs 7.20's consistent. Never had it on a 1/4 mile, but I've been told it should go 11.50's.
I think you would be more around 11.20's 1/4mile.
You should be low 11's.... I run 7.0, 7.1 & 7.2's always 94 or 95 MPH in the 1/8th mile all the time & its always a low 11.. :)
Depends on his MPH in the 1/8th. Some impressive #s! Post up specs, would like to see some secrets.:joy:
Well it's 10yrs of trying different parts combo's etc. My current set up is stock bottom end 1993 era with hper pistons, TW's 170cc no port work, Holley Systemax, Anderson cam, aod with a 4500 stall, 4.30 gears, M/T drag radials, 2,800 lbs. With Good traction it will run 7.20's all day with a best of 7.19 @ 94.7 mph. in cold air. Thinking about spraying it with a 100 shot to see what happens?
He shows almost 95 MPH.. Thats good for low 11's anyday.. :)[/QUOTE
Some cars fall on there face after the 1/8th. Not saying his car will ! But seen some over geared 302s flat line! I would guess 11.40s -11.50s ! But then again you never know.:)
Discussion Starter #18
+1 LOL..............
+1 Sorry, fellas. MODS: Please close this thread. I searched EVERYWHERE for an N/A list and could only find the one for stock shortblock + power adders? :shakehead
Thats for 5.0's only.. Id say leave this open for everyone else unless there's another thread already.. I cant believe there wouldnt be?? certainly there's more non-5.0's racin then 5.0's these days :salute:
1 - 20 of 20 Posts
