May pertain to others years as well, but I recently had a injector plug break the retaining clip on my 04 GT. The only style plug I could find to replace it required me to cut the wires and splice it in. Are there any sources to find these plug ends that you can re-pin? I know the factory motorcraft ends can be pulled apart and re pinned, if only I can find a place that sells them, other than the junkyard where the plugs are questionable in the first place. Thanks everyone!
Discussion Starter #2
The problem I foresee running into, and what I have experienced in the past is diagnosing using factory wire colors. I'd rather keep factory connectors pinned into existing wires to help with any future problems rather than splice in random colored wires.
