all parts are for a 2011-14 gt, wheels, coilovers, fuel system save for rails are all compatible with 05-10. wheels are dirty but clean up nicely, car has been garaged for the past year so parts are dirty but in great shape.
weld rts polished set 15x10 w/ 28x12.5x15 et street bias ply 17x 4.5 hoosier 7.5's one front lip has a light bend, dunno how it got there as there is no rash. holds air and no vibration. wheels and tires only have 25 street miles total and no track time. SOLD
tein 12 way adjustable coilovers, rears have height adjust perches for rear springs , springs and shocks. fronts are assembled with caster/camber plates. as you can see these 12.5's et streets fit well with the 15x10 7.25 offset wheels. 1000 shipped
f1a procharger with a 15 lb and 28 lb pulley complete kit with big red valve. I am including a boss intake and 3 can catch can system ( main is vented)which worked flawlessly and is needed with this kit. also including 80lb injectors. this setup made 720 rwhp on a stock block at 15lbs. can provide dyno sheet if necessary. 5900 shipped & PP'd with all the extras
fore fuel system with twin aem 320's, good for 1200hp boosted, upgradeable to a triple hat. complete with stainless braided lines and all fore fittings, fore rails, fore adjustable pressure regulator with boost reference, fore washable filter and last but not least a fore fuel pump controller. the lines are all stainless but what shows in the engine bay has been covered in wire loom to clean up the engine bayyou will need to assemble a line from rail to rail. SOLD
