1 - 13 of 13 Posts
Stock Fox Alternator Worked great when removed.
$15
Stock Fox Alternator Bracket
$20
MAC Equal Length Headers They are a bit rusty but the do not leak and come with bolts. 2 studs are missing but can be replaced with bolts. These are for a 302.
$40
Stock Fox MAF, Air Box, Intake Tubing and K&N Filter Filter was just cleaned and re oiled and the air box has all clips and no cracks.
$25
Stock Fox Radiator Holds pressure and has no leaks, could use a cleaning.
$20
Stock Fox Radiator Shroud and Overflow Tank In good shape no cracks.
$20
Stock Fox Smog Pump Not frozen in good working order.
$10
ARP 7/16" Head Studs for Ford 302. Brand new. Installed on a motor and then removed due to going with a different block. Comes with everything you need.
$70
Fox Body Mustang Oil Pan. This pan has a fitting welded on the passenger side of the pan for an oil return line.
$35
Ford 302 Oil Pump with Fox Body Pickup. Oil pump has less than 1,500 miles on it. Like new. Comes with bolts and pick up.
$20
Ford Racing Oil Pump Drive Shaft. Ford Racing's oil pump driveshafts are made from centerless-ground chromemoly and have an increased diameter at mid-shaft, which is where most stock shafts fail. They are recommended for use in all performance applications.
$10
PM me if you are looking for any specific stock fox parts and I will see if I have it
1 - 13 of 13 Posts
