1 - 16 of 16 Posts
Well going to let my 86 gt go cant afford three projects at once. Car body has 200k+ on it motor 65k, Trans 12k. This car is by no means perfect or a show car but it does run very well and I have put alot in it already. I will breifly run through what is on the car.
Engine
stock 95 bottom-end 65k
Heads GT40's milled and mild ported
Crowler 1511 cam
Crowler valve springs (Made for this cam)
1.7rr
Prof products upper and lower(edlebroc style)
BBK 70mm tb
24lb injectors w/ aeromotive regulator
Msd 6al and coil
Nitrous Works plate kit (running 125hp shot)
Tweecer engine tuner
Wideband o2 w/gauge
Trans
World class T-5 10k on it bought new
Aluminum Driveshaft
Rear-end
31 spline trac-loc w/carbon discs
alloy 31 spline axles
4.10 frp gears
I have six matching rims (4) 15x7.5 and (2) 16x8 the 15's have street tires with good tread and the 16's have a set of ET streets with lots of tread.
I had started on the interior also has new carpet and new weatherstriping.
I know I am leaving out alot of stuff so any question just ask.
I am asking 3500.00 for everything. I would concider not including the nitrous kit and et's and wideband and letting it go for 2800.00 if someone wanted it for less.
Now listed on autotrader need this gone
http://www.autotrader.com/fyc/vdp.jsp?ct=p&car_id=272886046&dealer_id=64906105&car_year=1986&rdm=1262130107321&lastStartYear=1981&model=MUST&num_records=100&systime=&make2=&highlightFirstMakeModel=&start_year=1981&keywordsfyc=&keywordsrep=&engine=&certified=&body_code=0&fuel=&awsp=false&search_type=used&distance=50&marketZipError=false&search_lang=en&showZipError=y&make=FORD&keywords_display=&color=&page_location=findacar::ispsearchform&min_price=&drive=&default_sort=priceDESC&seller_type=b&max_mileage=&style_flag=1&sort_type=priceDESC&address=24502&advanced=&end_year=1993&doors=&transmission=&max_price=&cardist=0&standard=false
thanks
nick
Ok people bring some offers if I dont sell this in the next couple weeks I am putting it back as close to stock as i can and sell the parts than selling the car for 2k....
What is the bracket for under the hood? Looks like it was supposed to hold something.
1 - 16 of 16 Posts
