1986 Mercury Capri 10.80 @ 126mph best pass. 408ci windsor w/ Scat crank, Eagle Rods & JE Pistons. Anderson Hi-Rev roller Hyd camshaft, FoxLake Canfield Stage 2 Heads, Fuel Injected w/ 42lb Bosch injectors, 80mm Throttle Body, 85mm Mass air, Power pipe, Edlebrock Intake, Aeromotive A1000 fuel pump, Sumped Tank w/ 10AN ful lines,Pullies, Kooks 2"primary/3-1/2 Collector headers, 3-1/2 X-Pipe w/ 3-1/2 flowmasters, EPEC Computer system. AOD Automatic trans w/ Lincoln Gear set, PA Manual valvebody w/ transbrake, PI Stallion 4500 Stall convertor, Autometer Gauges,Aluminum Radiator, MSD Ignition, MSD 2step, MSD adjustable RPM box, 6point cage, harnesses, factory interior, Fiberglass cowl induction hood, 8.8 rearend w/ welded tubes, Full spool, 4:10 gears, 31 spline Mark Williams axles, TRZ adjustable upper control arms, Hotchkis lower control arms. Rear coil over adjustable suspension, Tubular K-Member, Tubular A-Arms, adjustable coil over front suspension, Hotchkis Polished caster camber plates, Drag struts and shocks, Adjustable Anti-roll bar, Centerline Warrior wheels 2 fronts 4" & 4 rears (street tires & 26x10 slicks), rear mounted battery with disconnect & outside posts. I have been the owner of this car since new so the history is all here. I have probably missed something in this description. Really an great car to race or play. Price barely covers cost of engine work in this car. Serious inquiries only may consider partial trades... pics upon request. Also have a
24ft enclosed trailer i will make a package deal with. Asking $15,000 for car only
