1 - 10 of 10 Posts
Wondering if I would be ok running a valve cover to header evac setup on the street. Motor is a 306, P heads and a Jay Allen cam. About 10:1 compression, and will see more street than strip for now. Or should I just run a conventional PCV setup?
no issues with the evac kit on the street for me. i only run one side tho and leave the other vc open to atmosphere. fixed my rear main seal leak:king:
I've had good luck with both.When I had a 306 I had a PCV setup that worked great.I've heard that for a evac system to work best you need a straight thru type muffler.For a fairly mild setup I'd probably stick to a PCV system.Tim
I had nothing but bad luck with mine. (Moroso header EVAC) The check valves kept failing thus allowing exhaust presure to enter the crank case. Look at some of my posts, I just installed an electric EVAC pump and catch can. Its working well so far.
1 - 10 of 10 Posts
