when rear axle centerline is up inside the car, ..more than stock,...( car lowered)
then you have issues with the trans or driveshaft hitting the tunnell..
you have to make compromises..
or you need to alter the tunnel....
So the motor and trans should be at 0 when the car is at normal height?
Meaning, measure the distance at the front of the motor to the center of the crankshaft bolt, then measure at the rear to the center of the output shaft.
