1 - 14 of 14 Posts
I have a 92 Mustang GT 5.0 and I've been having a random issue where I'm driving down the road and all of a sudden it just turns off, kind of like someone turned the ignition switch off. It will usually turn right back on by itself within 5 seconds, give or take. This morning I was driving on the highway and the radio cut out (shut off) for a half a second then came right back on; it did this twice. Then a half a minute later, the car shut off for about 2 seconds then came right back on.
I'm pretty positive it's an electrical issue somewhere, but my question is where? Is this possibly the TFI that's mounted on the front of the distributor? Is it something inside the distributor cap? Is this an ignition switch issue? Starter solenoid?? I'm not sure where to start diagnosing or how to diagnose whichever part is in question. In other words, if the TFI is going bad, is there a way to test it before spending the money on a new one just to find out that wasn't the problem? Any help is appreciated. Thanks...
the radio should clue you in that its not likely, tfi
engine off key in run, radio should remain on
you have an inter open somewhere, that reveals itself from heat and/ vibration
no easy way but to use your wiring diagram, and start at locations subject to heat and vibration.
yeah, or even a partial blown fuse link.
Indy2000: What you said makes a lot of sense. I really hope you're wrong though. Electrical issues and I don't get a long. I struggle troubleshooting electrical issues, especially in a situation like you're describing. However, inspecting the fuses is not a problem.
5.0 Thunder: I'll check that wire. That's easy enough.
Thanks for the advice guys....
Fuselinks are not fuses & you have to know what you're looking for if inspecting them.
http://www.autozone.com/repairguides/Ford-Crown-Victoria-Grand-Marquis-1989-1998/Circuit-Protection/Fusible-Links/_/P-0900c152801e4c04
Thanks for that diagram. So that's what I should be looking for? I presume I should start looking under the hood for such a wire since it's easier to access than behind the dash. However, in an effort to narrow down my search, should I be focusing on wires in the ignition system or could it be any wire causing the issue I'm having? Logic tells me I should focus on the ignition system, including the distributor, starter, starter solenoid, etc.....Am I on the right track?
I would cbeck tbe ignition switch under the shielding .
Not the key, the switch.
These are known to seperate and cause problems just as you described .
Most of the fuselinks are attached to the starter relay.
The ignitions switches had a recall back in the mid-90's. Any Ford dealer can look up your VIN to see if yours was replaced. If not, they may still do it for free. Safety recalls do not expire.
95S28 NOV 95 Safety Recall 95S28 - Ignition Switch Replacement
Thanks for that valuable info. I'll definitely look into that....Question, if none of the fuse links at the starter relay are frayed or look damaged, how do you determine if there is a problem with them or not? How do you test for a damaged fuse link? Ohm meter? If so, what ohms should it read?
do NOT use an ohm test
you perform a voltage drop across that link, with the circuit energized
one lead on one side the other lead on the other side.
you are trying to see if the link can carry the proper current, your ohm meter puts out very LITTLE current, therefore is a useless test.
ohm testing is good for shorts
Discussion Starter #13
I assume I'm looking for 12v across the wire? Is there a range that's acceptable?
you are looking for less than 0volts for good
if you have battery voltage across that , the fuse is OPEN, blown
1 - 14 of 14 Posts
