So I got a derale electric fan hooked up with a DC fan controller. Has been working fine the few times I drove the car.
Now the fan is like pulsating when I drive it. It gose off for like 5 seconds then gose full power then shuts off, dose these constantly.
Everything looks wired up fine, any ideas or what i should check?
confirm power and ground, and solid sensor connection
after that, the maker of the control will need to be contacted.
its solid state non serviceable part
he would need a fuse to blow one..seen cars wired directly to battery with no fuses in circuit, also lots of bad terminal connections.
if there is no fuse, and a short, the temp of the conductor goes to the temperature of the sun in an instant, and melts
