1 - 18 of 18 Posts
Are you asking how much boost the turbo can make before it's out of its efficiency range, or how much boost your hotside will support?
well i build is a 331 with afr heads 185, and sprider intake i really cant find any other info on the turbo right now. but im only looking to go to 17psi
Even without knowing much info, a T67 with a .81 a/r is not going to make great power across the entire powerband on a 331. It will have great torque (maybe too much), but it's going to run out of steam pretty fast.
Discussion Starter #12
Compressor:
Inducer: 66.6mm
Exducer: 84mm
Inlet: 75mm
Outlet: 50mm
Exhaust:
Flange: T4
Outlet: 3” Vband
A/R: .81
Inducer: 74.2mm
Exducer: 64.5mm
Its a wide range, but it all depends on how fast you want to go. Hotside would be the traditional 1 5/8 primaries with a 2 1/2 crossover will be enough unless you are looking for a 7 second timeslip...lol
This is pretty correct. The T67 makes a lot of torque, just had my sn95 dyno tuned yesterday 312hp with 387ftlbs completely stock just the on3 setup @6psi - My turbo is also journal bearing not sure if that would make a difference but I was surprised with the torque numbers.
1 - 18 of 18 Posts
