1 - 14 of 14 Posts
how much did it make on the to boost level's? is your car a stick? I like the videos man
Will have some action videos soon. Car was running 12.20's @ 109 on motor before the turbo and 11.30's @117 on a 125 shot (to the tires). Can't wait for my 10.xx time slip.
@ 12lbs made 398/512. Didn't ask for print outs because I'm not a big fan of dyno racing. As long as it meets my goals I'm happy. I want a 10 second street car with a/c power windows,locks,seats. Oh yeah that was through an auto trans with 3800 stall
What's the rest of your combo? (H/C/I) Is it a C4 or AOD? Stock block?
combo is stock block,crank and rods. -.030 over SRP's. probe main girdle. ARP everything. Vicjr heads, Comp cams 274hr (for now). Typhoon intake gasket matched to the heads (Felpro 1262) 1.72 rr. Probe rocker girdles. All balanced, block was drilled and tapped for windsor head bolts(9/16 I think) ARP head studs, block O-ringed with cooper head gaskets. TCI Full comp C4 RMVB-no brake. TCI street fighter converter with the anti ballooning plate. 8.8 with 9" axle ends 33 spline mosers. Wilwood 4 piston disc's on the rear. 373's for now. 275/50/15's . Full UPR suspension -antiroll. Going to be picking up some 275/60's this week, and thinking about going to a 355 or 327 gear. 42's maxed out on my high boost tune. 70/81mm masterpower
Nice combo for sure, good luck at the track. With 327's you'll be plenty into the low 10's. I just upgraded from 42's to Siemens Deka 60's as they were maxed out as well. I'm seeing 50% duty cycle at 5000RPM and 8psi now.
Very nice build!!! Keep us updated on that 10 second timeslip...it should be a piece of cake for you, even with the 3.73s.
1 - 14 of 14 Posts
