looking at getting a set of g-Force T/A Drag Radials in a 225 50 15 flavor for my stock turbine rims
anybody run these, how do they work for ya? is that a good size for my stock turbine rims? my car isn't a high hp car so i think they will work good for my car.
description of car in sig
thanks for the help
that's a really short tire.
I'd consider the BFG 235/60 or the MT 255/60 for the stock wheels.
I have them and they are a short tire but IF your not geared too high it works out good !!
I ran 3.45 gears and with the small tire I still had enough gear to make the finish line. ran 13.6s at 101mph with 1.8 60 foots on them tires with a stock motor
the 235/60s are prolly the hot ticket the 225 are short/small and the 255/60s bulge pretty good on a stock rim. I have have both the 225/50 and the 255/60s on stock ten hole rims and the 225s look small and the 255s balloon pretty good. I can take pics of both IF you want to see what they look like
thanks for the advise i think i will go with a slightly larger tire as i run 3.73s
get m/t's..i tried bfg's on my car,they wouldnt hook anywhere close to the m/t's..i run a 235/60-15 (26x9.5) those fit great on turbines
