Are the Door Locks on a Negative Output, or a Positive Output? I'm getting an alarm and I'm curious beacause I have to buy a harness if its Positive Output. Thanks!!!
Re: Door Locks, Positive or Negative Output
Pete:
PM me Monday morning when I get to work. I can tell you for sure then. I can even have the entire harness schematic faxed to you if you'd like.
--Andre
The door locks are negative pulse I am 99% sure. I hooked up an alarm and had a heck of a time doing it. The wiring schematics are horrible for the door lock system in this car. They go from main power to the driver door (master lock), then to the passenger door and back over to the drivers door. I could not get to the wiring harness which is jammed in the drivers side kickpanel with like 400 different wires. To get mine to work I had to use two relays and hook the out put wires to the lock panel in the passenger door.
