1 - 10 of 10 Posts
Going to do it this afternoon and I have read before that some people were having trouble. Just wanted some opinions to make the install painless. Thanks!
you need a pulley/damper/steering wheel puller. Got mine at sears for $19.
Get some rtv sealant because it is needed.
Clean oil for lubrication of crank pulley.
It's easy. Just follow the instructions and you're good. I'd also recommend taking the whole starter over to Autozone (or equivalent) to have them replace the starter pulley for you... Having a friend help you put the belt back on also helps. The tensioner is so strong you'll need a crowbar to hold it in place while a friend makes sure the belt is on all the pulleys correctly...
Starter pulley????
I thought it was the alternator pulley that AutoZone will do? I think I read that people have the hardest time w/ the crankshaft due to a rubber (fill in the blank :confused: ).
that rubber stuff doesn't make anything hard. if it does, pull it off, and put on some rtv sealant.
Its the alternator pulley that needs an air impact wrench to get off and put back on. You need to go to the auto store for that.
Do all of the above and don't forget to have the Autozone people change your blinker fluid and muffler bearings at the same time. It will make the tensioner not as tight. :p
1 - 10 of 10 Posts
