I am in the process of assembling my build and am wondering if anyone has had any luck. I already have the first tech and turbo system going of a 351 w 205 heads. Checking cam and then push rod lengths next and then valve clearance. What fuel pump will work? I know it needs to be 58psi. I am super nervous about this fi tech but I'm all in now.
I use the Fitech1200 on my setup. Very happy with it so far. Been 6.0s on 11lbs and put over 600 street miles on it. Sbf/s480 setup.
Go join the FiTech Users groups on Facebook. They are LOADS of help on this.
nearly any efi fuel pump will make more than enough pressure. determine how much power you'll make them size the pump accordingly at 58psi (most are rated around 40psi).
