I do... Tokico illumina 5-way drags
I run the fronts at 1 and the rears at 3 for the strip, i have only been out on them twice so i havent really played with the settings to see what happens yet.
I also run an airbag in the right rear at 20-25psi, and no front or rear sway.
best 60 so far is a 1.68 but like i said ive only been out twice on em and when i did the t56 swap i lost a ton of 1st gear so thats hurting the dig too.
I have them and also have not tried setting them for the track. I did bust up the dial on the driver side during a spring install. My question is if you keep turning the dial does it throw the setting off???
Example: the dial read 1-5, but the knob will turn pass 5 and back around?
