As the title states, I know aerospace front brakes make the tires stick out close to another inch. Is there a problem with the fender hitting the tire when launching or is it ok? Also, how much weight do you save with rear aerospace brakes and do the rears do the same as the front as far as the tire sticking out more? I run 17" front runner greg welds and they are perfect right now but I want to save more weight. If the fronts wont work out, I might just do the backs. I have greg weld 15x8's but I dont want the tire sticking out if rear aerospace brakes change the geometry
Go with the "floater" Aerospace kit that move the wheel/tire IN by approx .75". The reae will be spaced out the thickness of the hat the rotor bolts too - maybe 3/8"
i weighed the drums, springs, shoes, everything....then weighed aerospace race brakes for the 8.8.....5lbs lighter.
