i have the on3 70mm turbo..... That i am doing a diy turbo kit... I have a treadstone hot side so the turbo will sit the stock place excatly like a on3 turbo kit does...
1. what size oil line for the inlet are they running...
2. how long... I thought like 3 ft
3. whats the size of the oil fitting on the inlet for the turbo
4. it will be a brand new motor probly around 60 lbs of oil pressure maybe more... do they recommend a oil pressure regulator if so what size
I am just doing rubber line with brass fitting for the drain.....
For my DIY setup, I used the smallest brakelines I could find going into a fitting with a restrictor in the elbow (for your single turbo, see what they are fed thru in the kit). For a drain, you want as big as you can go (10-12 AN equivalent). In a way better to use the brass fittings like you are-it is low pressure. Make sure the drain is as short as possible and does not go horizontal or up hill.
Erich
