1 - 10 of 10 Posts
Just like the title says,how fast are you running with this differential.
I'm considering this to replace the pain-in-the-ass-spool thats currently in the car :)
I have a detroit truetrac in my car for over 2 years with no problems. The fastest my car went with it was a 10.77. The unit is a little heavy but its built to last and take a beating. My runs at the track are with full slicks launching around 5500. I went to this unit from a Powertrax unit which only lasted 1200 miles. You wont be disappointed.
From Jegs, Its been ahile so the price may have went up.
Ive run 10.04 at 148mph and multiple 10 sec runs on a basic Ford Racing Torsen diff....
3600lbs weight.
I tried a spool for a while last year. What a POS, never again will I have such a thing near my car. And it didnt make one pick of difference to traction.
back to a Ford Racing Torsen again :)
3600lbs weight.
Yup, I'll never have a POS spool again. Total pain in the ass.
What exactly is the ford racing torsen differential your talkin about? Never heard of it....
^^its made by Torsen, thought by some to be the best torque sensing diff in the world. (they are expensive)
Some of the 4th gen F-bodies came stock with them.
Its usually run on a car for road course purposes, as ive never seen anone run one for serious drag... but according to this guy it works fine and i dont doubt it.
Exactly as Arcangl says. Its just a Ford Racing part.
I actually run my best times on 28spline and the Torsen. Although after twisting a shaft or 2, I upgraded to 31 spline.
To get me on the road quickly and cheaply, I bought a spool.....never again.
I think I had been using the 28 spline Torsen for about 3 years before upgrading to 31 spline
I soon reverted back to a 31 spline Torsen ( I got mine from Summit, but any sponsor here should be able to supply ). Im now using MW 31 spline shafts and the Torsen.
Comparing 60fts between spool and Torsen, I personally seen no difference whatsoever.
My best so far, has been in the 1.7x range on 255/50x16 MT DR's
I hope to try some ET Streets soon at a proper drag strip and reduce that further.
I did try them at a venue in Denmark recently, but it isnt a full on drag surface, and was totally unprepped. I did manage a couple of 1.7x 60fts, but only 10.4 at 142mph best.
1 - 10 of 10 Posts
