I just got the Densecharger fenderwall-throttle body unit. I was reading the instructions and cant find where to use the gasket sealent they supply you with. Does anybody know?????
Thanks,
Eric
Speaking of Densecharger install, did anyone else have trouble fitting their filter into the fenderwell, mine didn't want to fit too easy.
I never used the gasket sealent.
Once you're happy with the orientation of all the piping, use the sealer at all the joints. I was able to see rather large air leaks (using a flashlight in a dark room) using the screws alone. To avoid unfiltered air getting through, seal it all up.
The pipe can be a struggle, but it WILL fit. Take your time - it's tight. If you want a better handle on it all for just a tad more work, remove the tire/wheel and the fender liner - then it's a piece of cake.
Good luck!
- Dave (SCOA #1474)
'01 Cobra Coupe (Laser Red, Charcoal), no wing
- #812 of 3867, born 5/7/01
- Dyno results (7/10/01): 273rwhp, 277ft-lbs
- Best ET: 13.748 @ 102.128, 60'=2.264 (7/18/01)
- Potenza RE730, 275/40/17, on CobraR wheels
- Bassani CatBack system (8/1)
- Griggs sub frame connectors (8/18)
- Steeda shifter and Cobra grill emblem (9/26)
- MM strut tower and K brace (10/13)
- 100MM Densecharger (10/27)
- MGW shift lever (1/14/02)
ok thanks
