Im running a carbed SBF and im looking to record some data. The Innovate LMA-3/PL-1 combo looks like it will fit the bill. Can anyone recommend something that will compete with this setup at a similar price point ($3-500)?
Needs:
RPM
AFR 0-5v
MAP
Speed/DS sensor
Built in accelerometer
Looking at the site, the sample rate depending on what you're doing could be a weakness in it as compared to more expensive units.
Here's one I've seen used.. I think Dave Wolfe was using this back in the day
RPM Performance Racing Electronics, Data Loggers Systems, Sensors, Nitrous system
Then there's the industry leader..
RACEPAK - Professional Racing Data Acquisition & Instrumentation ? Racepak
Those are def better solutions. Def more expensive tho. Just looking to capture some simple data so im not in the dark.
What do you think about this one?
AQ-1 Data Logger
I have a used Altronics data quest that would be in your price range. Will need extra sensors to capture the other data points though.
