I just purchased a 2003 GT with a Procharger D1SC on it and would like to change the oil in it. How much oil do I need to refill it with and what type of oil does it take, I see Prochager makes oil is it all the same type?
Procharger oil is the only "certified" oil to use and it's 6oz. I personally use Royal Purple XPR 20w50 in all my Procharger units with never an issue.
Got the oil from Procharger, Do I drain the oil and fill from the 2 allen head bolts? Or do I fill it form the screw head bolt on the top opposite side of the unit?
Fill from the flat head screw (dip stick). Drain is on the bottom of the unit and should be a normal bolt. Don't remove the allen head bolts from the side.
Thanks, found the bolt on the bottom.
