Would you buy ported heads with deck surface corrected valve job corrected springs corrected from reputable shop for $1000 or out of the box heads for $1200?
which out of the box heads are you referring to? it does make a difference. same with the machined head. is the machined head a stock head done up right? are the out of box heads one of the good aftermarket heads?
need more information.
