what have you used to cut the cold pipe to install the protube? also does the cut end have to have the lip rolled to prevent the hose from coming off under boost or will it be ok? how have others performed this step?
thanks
i've used sawzall or die grinder with cut off wheel. i did not roll the lip and have never had a problem.
thanks for the reply. I'm at the muffler shop now and they gonna do it for free. :)
Old bmx trick: Spray the end of the pipe with some hairspray.Slide the coupler on and when the spray dries, it is on there good.Have had couplers on under 30 plus lbs. of boost and not slip.
