1 - 8 of 8 Posts
Someone recently posted a pic of the cutoff switch behind the license plate, I'm about to do that and was hoping on seeing the pic to just see the positioning.
Thanks.
why would you do that? do you know the purpose behind the cut off switch? its for safety... if you're wanting to hide it you apparently aren't worried about safety, so why worry about even putting it on there?
You can take the 2 screws out that hold the license plate when you go to the track....Keep the plate on when you're on the street.
It's a clean install. True story!!!
mine is behind the plate too. I just remove the plate at the track.
I used rubber bushings as spacers.
It's positioned similar to the one above.
1 - 8 of 8 Posts
