Looking to buy an engine, trans, computer, wiring, and fuel tank out of an f150 to swap into my 1986 f150. Had a 351W in their and it just threw a rod the other day. Would prefer a low mileage engine, and must be in good mechanical/ working condition.
I'll Take 6k for everything.motor,transmission, wiring,ecu,fuel tank, drive line,radiator,fan everything had 36k miles wen pulled out of car
Yes the f150 coyote is cheaper, but watch what yr you get. Do your research on everything you are asking for. I have engine harness for a 2016 f150 coyote that I will sell, but again do your research first.
Do the research on the stock eec/ I had the setup out of a f150 without the body eec. I had the motor eec. Unless HPtuners has a pats delete for the coyote you will need the FMS computer. If you get the body eec your fine and is the only way of controlling the 6r80 tran with a stock eec. Make sure to get the steering wheel with the key and all the wiring to and from.
