i'm having trouble w/ my stall
i have a ati 5500 8" behind a alum headed 347 making about 400 to 450 hp
my prob is it will spin the tires at 2400
oh by the way it is in a 78 fairmont weighs 2700 Lbs
i would like to see atleast 3000 on the footbrake any ideas ?
thanks joey
The 5500 stall would be more with a trans brake...your brakes are only going to hold to about 2800 or so...you could go with some aftermarket brakes like ones from Strange...they will hold.
i know i'm not gonna see 5500 i would think at least 3000 though i mean it does flash about 4100 or so got a friend running a similar set up in a lighter car and his will go 33 or 3400 stock rear brakes
that's why i have trouble seeing why mine won't go atleast 3000
The brakes are not holding it. the converter is not the issue
Tim
I have a 3500 stall, so far I've gone up to 2800 on the brakes (stock) with no problem and think I can go higher. So I agree with gray86hatch you need better brakes or the ones you have redone.
it's fixed!!!
I fixed my problem turns out the rear brakes were not good enough
here is what we did to fix the prob
went to the local napa store and found a bigger bore set of
wheel cylinders that fit original backing plate
here is the funny part i ordered 79 Pinto wheel cyl
the stock ones were 3/4 bore the Pinto's are 7/8
before the chage the most on the footbrake was 2500
changed cylinders and have seen 3600 on a crappy floor
prob will go 3800 to 4000 on a good track
just thought i would let everyone no incase some others
are having a similar problem
thanks for the replies
Joey
