1 - 15 of 15 Posts
you need more gear
Get the trap rpm just over peak power 2-300 and the slipage will go way down
The converter is not going to lock up with that highway gear and low rpm
Tim
Well u havent had the chance to lookin to that much what gears are recomended? I do run the 1/4 every once in a while looking to trap in the 140's its a turbo car if thar makes a difference
Use a calculator to determine the trap Mph RPM conv slip of 12% and this will tell you what gear. If you turn it another 1500 rpm the MPH will gain big time.
Coverter slipage needs to be measured at peak rpm and MPH
Tim
Run it to 6500 in high gear and see what kind of mph you get. The converter in my car never gets below 5700 after launch. I turn it 6500 slips 12-13%.
Tim
Tim
exactly, you never said what the converter stall is. If I did your test in mine it would have terrible slip % since its about 6400 pull back on a shift.
So pretty much need to change gears or have the converter tightened up. the car runs 7.01- 7.05 in the 1/8mile shifting at 4700-5000rpms in high gear. What gear should i go with? weight is 3304 and the 3.31 gear with a 28inch tire
Don't do anything if you plan on going 1/4.
What kind of mph in the 1/8. Where do you shift into 3rd.
Tim
With what you have ran the car will go 125-126 in the 1/4.
1 - 15 of 15 Posts
