Need to swap to newer style spindles,
can I get by using the same rotor/bearing/caliper ?
You need to use 87-93 rotors, spindles and calipers. The outer bearing is the same, the inner one is different. You will also need new rubber brake lines and banjo bolts. The dust shield is also different.
And as I did with my 84, it's also a good time to go for the 73mm calipers. And you also need to know that the strut is different. And it's also a good idea to swap to the newer style ball joint.
What I did is found the spindles and loaded calipers used. I bought FMS arms and springs and Tokico struts, along with all of my other suspension parts. Did it all at one time.
You'll also need washers for the strut where it mounts to the spindle, or get new 87-93 struts.
