Trying to see this from other points of view. Could you
successfully use a turbo/centri. supercharger compressor inlet to pull crankcase fumes, acting as a vaccume pump? Of course you would need an air/liquid seperater and filtration.
Yep, factory Buick Grand Nationals do this. The issue is that there is a lot of oil/water vapor that will get sucked through the turbo and a separator will only collect a small portion of it.
ks
