when using the little tool to compress the rear calipers, which direction do you turn it? Dumb I know, but I'd hate to pay for a brake service, unless they could machine bleed all 4 corners too, haha.
I have some pads, and new rotors, and I have a lot to go on each. I tried clockwise with the tool, with the resevoir cap off. I dont think that was right, because they turned, but after 30 minutes, didn't show signs of recession.
That is wierd.
The pistons are essentially sitting on a jack-screw - it will only take several turns and they should be re-seated. If they are spinning and not going back in, they have probably pushed out to far and come off the threads. Try giving them a push to see if they will seat and then turn them (clockwise is correct, just like a screw).
another problem I have is that the caliper slides both have 1 frozen on each side. Is there any good way to unstick them besides forceful application of hammer?
Or should I just upgrade the rears anyways since I have upgraded the fronts?
oddly enough, they're covered in it.
Give the face of the piston a few firm strikes with a soft faced hammer to reseat it. Occassionally, the piston will extend to the point that it becomes unseated. This has worked for me in the past.
