1 - 9 of 9 Posts
Just finished hookin up my returnless system on my 02 gt, my question is, how much can it support?
-10 to the magna fuel protuner 625 pump
-8 to the engine bay Y block
-8 to the fuel rails
-8 to the regular
-6 back to the tank
Finally had to go back to -10 to get back in the tank.
I had the car idling but am waiting to get it tuned. Any helpful input is greatly appreciated!!
Discussion Starter #2
Nothing?
If it is returnless fuel system, why does it need a -10 back to the tank? And is this a N/A or boosted set up? That will determine HP potential, along with the size of the fuel injectors.
Return setup, boosted setup. Running about 12psi or so for now
Your first post said returnless, so I had to ask about the return line... That being said, the fuel system should support about 1K power if the specs provided by MagnaFuel are correct.
Also assuming you are burning gas, not E-85 or Methanol
I miss typed on my 1st post, i apologize. Magnafuel says the pump is good to 1500 and the regulator is good to 2000. that being said, i will be tuned to e85 shortly. Im just curious about what limitations im going to run into with the fuel is all
Forgot to tell you 60lb injectors are stuck in place
1 - 9 of 9 Posts
