For Sale Zapp Racing Engine built PI headed 2 Valve (Current ET Holder for this combination 10.80 @ 2900 lbs) No expense spared on this powerplant. Was only used for 6 dyno pulls and 4 races it's just barely broken in. Just add .575 lift cams and you will have a very competitive powerplant. You will be able to run at 2775 lbs in Factory Stock trim with a stick or 2575 with an automatic. Asking $6,500.00 that's 35 cents on the dollar from it cost to build. My loss is your gain!
Teksid Block
Neutral balanced crankshaft
R&R custom lightweight rods
Diamond custom lightweight coated pistons
TotalSeal custom ring pack
Coyote oil pan
Billet oil pump
Innovators West balancer
100% ARP bolts throughtout
2004 Mountaineer PI heads
Comp custom grounded cams
GT500 followers
GT500 lash adjusters
Colyes chain set
Moroso cam covers
Ford Racing PI intake
Accufab 70MM throttle body
Spare set of rings ($1,500 value)
And there is Much Much More
Does come with everything seen in the picture.
REVISED PRICE THIS MOTOR NEEDS TO GO!!!
For Sale Zapp Racing Engine built PI headed 2 Valve (Current ET Holder for this combination 10.80 @ 2900 lbs) No expense spared on this powerplant. Was only used for 6 dyno pulls and 4 races it's just barely broken in. Just add .575 lift cams and you will have a very competitive powerplant. You will be able to run at 2600 lbs in Factory Stock trim with a stick or 2325 with an automatic. Asking $4,500.00. My loss is your gain!
Teksid Block
Coyote oil pan
Billet oil pump
GT500 followers
Colyes chain set
Moroso cam covers
