im selling my Wilson manifold nitrous pro flow kit. im selling the kit since im going with a turbo. i bought this kit from another member with low miles on it and only have about 6 bottles through it myself. the system works great, i added a few accessories to it to make it the easiest and safest way to use nitrous IMO (with atleast a wideband). the kit includes 2 10lb bottles both with brackets and gauges. one bottle is the pro flow bottle and the other is a zex bottle. the zex bottle has a custom blow down tube the other does not. all included lines, brackets, solinoids, purge, nozzle, all the jets with the kit, momentary purge button, toggle switches, harris nitrous filter, bottle heater, sending unit for the heater. all relays, wiring, MSD RPM activation switch, nitrous pro flow TPS switch and a harris speed works Micro edge nitrous controler. i will also toss in a used set of autolite HT0's less then 10k on them. well over a thousand dollars for all these parts that are included, im asking $800 shipped anywhere in the lower 48. kit is still in the car as of right this second, as soon as i have a buyer i can pull it out of the car. please reply or pm me if you have any questions.
Located in Cape coral, FL
