Bought these for use in a 351W I built, hydraulic roller with link bar lifters and canfield heads. Ended up going to a 418 with solid roller, so didn't need these. They were mocked up, but that's it, never ran, been soaking in a tub of oil since I took it back apart.
$90 shipped in the US for the full set of 16.
www.summitracing.com
COMP Cams 7993-16 COMP Cams Hi-Tech Pushrods | Summit Racing
Find COMP Cams 7993-16 COMP Cams Hi-Tech Pushrods and get Free Shipping on Orders Over $99 at Summit Racing! As cam profiles get more aggressive and valve spring pressures increase, it is even more critical to select the right pushrod for your application. COMP Cams Hi-Tech pushrods are designed...
