1 - 9 of 9 Posts
Are all coils the same? What differentiates a coil specified for an EFI foxbody vs any other coil, besides the obvious wiring connections.
Number of turns
Coil saturation time
Type of Iron core used
I take it any one of those three things can make a coil suitable for one application not so suitable for another?
yes or a combination
cd or inductive ignitions have different needs
So any coil made for CD ignition will work with......any CD ignition?
that is an engineering question
therefore you go with the recommended coil for the ignition you want to use.
That's kinda what I figured, when my ignition company says to run a $230 coil I begin to wonder if there's an alternative to that coil......or that ignition completely.
if you can get the specs, you can try to match for cheaper, might not be better
there is a good reason why the stock coil works so well with the stock ignition
and why a CD ignition is not really that good for a street car
For the time being I'm going to run my MSD 6530 ignition, later this summer I will be switching to an EDIS. MSD and the lovely internet give conflicting recommendations on what coil to use.
1 - 9 of 9 Posts
