I've read all the spring rate and dampener info on MM website and have determined I need to go 400 front and 275 rear with the either the MM sport or mm2 dampeners. My car will be used for 90%track(HPDE)and I'll drive it to the track(30 mile round trip) and to a few carshows but not a daily driver. I already have UPR front/rear coilover kit. My question is will the MM springs and dampeners be compatible with my current coilover kit or do I need MM coilover kit as well? I also would like suggestions on either the MM sport or MM2 dampeners. I'm leaning towards the MM2 because it's not a daily driver. I'm changing my car over from a street/drag oriented car to an OTD car this winter. I'm in the process of converting it to 5-lug, 13" stop tech fronts and NRC rear cobra disc conversion. I've also picked up an 8-point cage,race seat and harness. I figured it would also be a good time to change springs/dampeners. The car is a 1985 347/tko 600 Thanks.
Send MM an e-mail. Use their site link. Or call them. The nice thing about an e-mail is you can write your thoughts, needs, expectations in a Word doc, edit as needed and then copy and paste into the MM contact info box. In this manner, you won't forget something while speaking on the phone and MM will have a better idea of current and future setups.
