Status
Not open for further replies.
1 - 8 of 8 Posts
Practically new Cushman Motorsports (CMS) Stage 3.5 Blower cams for a 2v engine.
I got these with an engine I bought, but don't need them. The previous owner ran them in Trickflow (TFS) heads for approx 5k miles.
The cams were CHECKED for proper intake centerline, I was told by previous owner that they were "Close enough and were installed straight up". This was in Trickflow heads, where PTV clearance is not as critical. If using in stock/ported OEM heads, cams MUST be degreed properly or valve damage may occur. I am not responsible for any engine damage that may occur if proper installation steps are not performed.
Cam Specs as per CMS:
The big boys of the blower grinds! These cams are ground on NEW steel billet cam cores! Aggressive street/strip profile. Aggressive idle. Supports 800+ RWHP. High load Valvespring upgrade REQUIRED.
.545/.545 lift, 242/248 .050 duration, 115 LSA.
$450 Shipped OBO
Are these designed more for centrifugal blowers? I am building a motor for my HD F150 and am trying to find some good cams for my M122 swap.
1 - 8 of 8 Posts
Status
