1 - 14 of 14 Posts
I need to sell my 86. This car is really clean and has never seen a winter. I'll just list everything that is done to it and if you have questions you can email me. GT-40 intake with ported lower, GT-40p heads ported also, all port work done by Fox Lake,1.85 intake and 1.55 exhaust valves,58.2-58.33 with 86 flat top pistons. It's got 4.10 gears,aluminum drive shaft, driveshaft safety loop, aluminum flywheel, motorsport h.d. clutch, Hurst short throw shifter, Hurst line lock, H.D. t-5 with phospate coated gears with 3.35 1st gear, steel throwout bearing shaft, off road x pipe, shorty headers p specific, motorsport wires, cobra 1.7 roller rockers, Lakewood 70/30 struts, Eibach drag suspension, air bag in right rear spring, steeda lower control arms, motorsport h.d. uppers, subframe connectors welded and frame tied. It's also got a new starter and a new alternator, a 160 hi flow thermostat and a motorsport windage tray in the oil pan. The car goes 12.50's on drag radials and 12.30's on slicks. The factory rims and tires come with the car as do the slicks all with about 80% tread left. I will email pictures by request. asking 6000.00 obo
1 - 14 of 14 Posts
