changing coil over spring?
I'm going to be putting in some qA1 12-150 springs to replace the 12-250 that are on there now whats the easiest way to swap? I have tokico illumines up front as well would I just remove the 4 nuts at the top of the caster camber plates and the 2 at the bottom on the spindle and lower the a arm down and pull it out? or would I remove the big nut on the strut? Thank you guys
Thank you very much!!!
Quick question car weighs 3050 and about 1600lbs is at the front tires what would be a good spring rate for drag 12-150?
