Ok, Ive had an issue with my fuel randomly cutting off and I checked fuel pressure, and spark and its all in check. I opened my ccrm module and my r12 resistor is bad its fried to the point where I cant see the colors on the resistor to replace it. Does anyone have one open that can give me the correct resistor color? Ive seen schematics for a 96 but it has an extra relay to the left of the fuel relay. So i dont know if its the same.
fuel is cutting randomly, yet you say fuel pressure is in check?
Yes while this issue happens the pressure remains the same and i have tried another set of injectors and same issue. I opened my ccrm and 1 resistor is fried right next to the fuel pump relay.
then how do you know fuel is cutting, with new injectors and no loss on fuel pressure?
