For replacing a CCRM (relay module unit), the electrical connector is bolted to the CCRM correct? Just remove the bolt, unplug, remove reservoir and replace ?
yes, but disconnect your battery terminals first
Ya, I've left it connected for everything (even a solder job on wires.) but for PCM/CCRM I'll take the disconnect advice... at $80 the CCRM isn't cheap to replace lol.
Thanks for the help.
