1 - 20 of 41 Posts
I have been reading a LOT of 'cooling mod' threads lately. I have also ran across outside sources that offer options to reduce the heat on those seemingly problematic rear cylinders.
I have also ran across a few articles that claim that this is not an issue, or state that the issue is so insignificant that there is no need for a cooling mod.
I am not bias either way. I am just looking for more substantial evidence to sway me in one direction or the other.
Here is one article explaining the lack of cooling mod need.
5.3L BigBore Stroker + 2.9L Crusher = Awesome!
Thanks,
Jesse
Better safe than sorry for a very cheap/easy mod. This article gives 0 evidence of why they feel the mod is not needed and also doesn't seem to realize that NOS is a brand, not the actual N2O.
Then there is the whole fact that Ford spent a lot of time/money to modify the 03 heads to fix this problem for the run of 04 and 05 heads. Doubt they would have done it if there was no need...
I did not know the '04 heads were different then the '03 heads. I am always one to overkill, so I might perform the additional mod for the sake of it. Have you modded yours?
Don't have a 4v... yet... but I know ppl who do and I've done a ton of research. Yes, Ford revised the revised 03 heads and all of the ones that are "fixed" have a blue mark on them to denote that they are the ones with the cooling fix. All 04 heads had it IIRC and definitely all 05 Aviator heads.
Sorry to say, but that is controversial also. I just sold some 03 mach 1 heads that were blue.
DOHC Cooling problem/revised heads
This would be a good read for those interested. Cobrabob and tousley ford parts participated.
So my best bet would be to perform the cooling mod (which ever one seems to be the best), I am leaning towards the MMR setup myself, or score some '05 Navi heads. Not sure how the fitment works on heads from year to year and head to head.
Best all around heads are supposed to be the 03-05 revised dohc 4.6 heads. Although there are plenty of ppl making big power with B and C heads too...
That is great to know! I was kicking around the newer Boss 5.0 head idea as I may just swap the block before the install. Do you know where I can source some revised 4v 4.6 heads?
Ebay, craigslist, here, you can still buy them new from ford racing iirc but its pricey.
Discussion Starter #13
All dohc 4.6 four valve heads that are not B-heads, are C-heads including the revised 03-up.
So lemme get this straight. B heads are NOT revised. C heads are? What did they do to the revised heads that make them 'cooler' than the older ones.
Oof, someone needs to do some reading... the revised 03-up heads are superior in multiple ways. They flow better, revised short turn radius, way better exhaust ports etc...
Google, she knows much.
For flow and power, a common 03-04 head will outflow prior "c" heads as they were a revision in design of the previous "c" heads. The actual water cooling redesign is strictly known as the 05+ revised heads.(as noted in link above)
If you have deep pockets and want the best flowing heads, you'll be looking for the rare fr500 heads or use some "gt" heads with a custom intake.
Discussion Starter #16 (Edited)
I have been googling the hell out of this. Getting mixed information and not sure what sources to trust. Here is an article I just finished reading that contradicts info I have read elsewhere, but seems to substantiate relative sources.
B/Swirl Port: (93-97 Lincoln Mark VIII, pre 99 Lincoln Continental, 96-98 Cobra).
The first and only production Ford head with two (square primary, round secondary) intake ports per cylinder, these swirl port castings arrived first in the ’93 Lincoln Mark VIII. Aptly named, due to the way they promoted the incoming air to swirl into the combustion chambers, much like water running down the drain of a once full sink.
Through the years these heads have proven themselves to be excellent high rpm (8000rpm+) performers—mainly in power adder applications--since their tremendous combined intake port cross sectional area and volume (when combined, a full 55cc more than any other 4.6L head design) provide for exceptional power production in the upper regions of the tach. Ironically, it’s those same big, beautiful, twin ports that also prove to be the B head’s largest inherent design flaw. The extra intake port size has a tendency to kill low/mid rpm intake port velocity and power production—hence the use of Ford’s first IMRC (intake manifold runner control) intake on the 96-98 Cobra. By allowing air to reach only one of a B head’s twin intake valves, velocity, and therefore low/mid range torque production was restored in situations under 3250rpm. Later head designs are clearly superior in this regard, which happens to be the one of the most important considerations for those wanting a stout street motor.
There is also some controversy over the single fuel injector/dual intake port setup. Some claim insufficient air/fuel mixing because of the compromised design, however, others contest that the ability to make 1000+rwhp with only minor porting and some form of power adder is testament to the contrary. Whoever you believe, there is little doubt that even after as little as 8,000 miles, carbon and other deposits tend to form on the secondary ports, causing a major airflow impedance, as there is no fuel present to clean them. B heads feature a somewhat small stock exhaust port that really hinders flow in power adder applications. Major gains from porting come with a quality valve job, some pocket and lots of exhaust work. There really isn’t a lot of material to remove from the intake ports themselves.
The Bottom Line: B heads aren’t the best choice for a naturally aspirated street motor. In order to really shine, they need to be paired with a power adder and a short block that can sustain high horsepower and rpm levels. These, the oldest heads, may still be a great choice for full race applications.
Stock Intake Choices: ‘93-‘97 Lincoln Mark VIII, ‘96-‘98 Cobra.
Aftermarket/Modified Stock Intake Choices: HCI, SSR, PHP.
B head dimensions: Combustion Chamber: 52cc, Intake Port Vol.: 107cc primary (square), 115cc secondary (round). Intake Port Entrance: 1.500x1.300” primary (square), 1.660x1.400” secondary (round), Valves: 37mm Int., 30mm Exh.
C/Tumble Port: (99/01 Cobra, 99 Lincoln Continental).
These second-generation Ford DOHC heads feature a single intake port per cylinder with a smaller cross sectional area that boosts incoming airflow velocity compared to previous years. To understand how C heads earn their “tumble port” designation, try to imagine an Olympic high diver doing repetitive front somersaults before cleanly entering a pool at the bottom. This controlled tumble allows for better air/fuel mixing than in the earlier swirl port heads. The new port design allowed for both substantial increases in midrange torque, and superior horsepower production under 8000rpm when compared with earlier heads. Combustion chamber size is also up 2cc.
The design downfall of C heads, and their larger (5.4L Navigator) cousins, is the relatively flat floor and utter lack of a short turn radius in the throat of the intake port. As such, the incoming air tends to overshoot the valves, making the port think the valves are smaller than they actually are. Some ‘99/’01 Cobra owners reported a “ticking/pinging” noise coming from the drivers side head of their cars. This is due to insufficient cooling around the #6, 7, and 8 cylinders that allowed the valves to overheat and therefore seat improperly. Ford remedied the situation by issuing a TSB to remove and replace the affected heads with a version that featured altered coolant flow.
C heads feature a small exhaust port much like Ford’s earlier swirl port heads, but unlike in B heads, both the intake (throat region) and exhaust ports can see extensive porting work. However, removing too much material from the intake port (mouth region) of a tumble port head will kill velocity very quickly, so make sure your head porter knows what they are doing!
The Bottom Line: C heads remain a viable performance upgrade for those looking for more punch in their street driven 4.6L four valve, without having to pay new part prices for the ’03 DOHC or FR500 versions. The increased midrange torque production and greater overall area under the power curve (when compared to swirl port heads) will enhance the performance of a street/strip driven (8,000rpm and under) modular regardless of application.
Stock Intake Choices: ‘99/’01 Cobra, ‘03/’04 Mach 1 & Aviator, ’03 Marauder, FR500.
Aftermarket/Modified Stock Intake Choices: Al Papitto short runner/ported ‘99/’01 Cobra, Sullivan, Aviator, '03/'04 Mach 1
C head dimensions: Combustion Chamber: 54cc, Intake Port Vol.: 177cc, Intake Port Entrance: 1.960”x1.350”, Valves: 37mm Int., 30mm Exh.
Navigator: (98+ Lincoln Navigator)
These 5.4L DOHC heads feature essentially the same intake port design as C heads, however they have a much larger intake port volume than 4.6L castings. Despite the fact these heads feature a relatively small exhaust port, the extra intake port volume could be very beneficial in helping fill a motor of greater displacement—think 5.4L. Expect slightly better midrange torque, and sub 8000rpm horsepower production than even C heads, however the larger intake port size leaves a slim selection of intakes to choose from when utilized on a 4.6L block. Forced induction fans take note, Navigator exhaust ports feature a thicker exhaust divider (while keeping the same overall exhaust port size as B,C, and FR500 heads) that allows coolant to circulate through this vital area. Conversely however, the larger divider can also hurt flow by utilizing additional space in the port.
The real downside to Navigator heads, when used on a 4.6L based motor, is the severe limitation they impose on intake selection. The physically larger 5.4L heads don’t leave a lot of room (when installed on a 4.6L block) between them for an intake plenum to sit—though they do bolt right up. Remember that since Navigator intake ports are essentially clones of those of C heads (just on a larger scale), they too suffer from the same intake port flaws that plague the earlier tumble port design--no short turn or floor in the throat of the intake port.
The Bottom Line: The extra port volume the Navi’s possess could be very beneficial in filling a motor with greater than 281 cubic inches of displacement, or in high rpm N/A street/strip or boosted combinations. Fans of boost should remember the cooled exhaust port divider. Lack of intake availability is the real downfall of this otherwise wonderful casting.
Stock Intake Choices: None (4.6L), 98+ Navigator (5.4L)
Aftermarket/Modified Stock Intake Choices: Al Papitto short runner 99 Cobra (4.6L), sheet metal
Navigator head dimensions: Combustion Chamber: 53cc, Intake Port Vol.: 184cc, Intake Port Entrance: 2.290”x1.400”, Valves: 37mm Int., 30mm Exh.
’00 Cobra R: (’00 Cobra R and now Ford GT/GT500 with .020" raised intake ports, unique adjusters, and better casting quality throughout)
Cobra R heads are bar none the best Modular heads available today. However, their extremely scare supply makes them both ridiculously hard to find, and unbelievably expensive.
Initial performance results are understandably hard to obtain, however Al Papitto reports that with only 25hrs of port work into the his new ‘00R heads, they have already eclipsed the performance of his old Navigator heads with months of labor in them. These heads feature larger intake and exhaust ports, +1mm larger exhaust valves, and a dry exhaust port divider. Cobra R heads also require the use of a specific valvetrain not shared with any other modular application due mainly to their overall physically larger size. Al also claims R heads have too much port volume for a street/strip 4.6L application; only consider them with a larger 5.4L motor or a serious 4.6L race application paired with some form of power adder.
The Bottom Line: The best heads you can or can’t find for a Modular four valve motor.
You are as likely to come across a set of these Modular “Godfather” heads as you are to be Catherine Zeta Jones' next uterus masseuse. Though based on their performance abilities, you may want to start saving, just in case…
Stock Intake Choices: None (4.6L), ’00 Cobra R (5.4L)
Aftermarket/Modified Stock Intake Choices: Sheet metal
’00 Cobra R head dimensions: Combustion Chamber: N/A , Intake Port Vol.: N/A , Intake Port Entrance: 2.370”x1.300”, Valves: 37mm Int. 31mm Exh.
Stock Intake Choices: ‘00R
Aftermarket Intake Choices: Sheetmetal.
FR500: (FRPP)
The sole “aftermarket” offering of the bunch, these high flow heads feature a modified C head intake port combined with the smallest port volume of the group—it seems Ford meant to design these heads for high performance naturally aspirated applications. With the same small standard exhaust port as most other DOHC heads you will still have to remove a decent amount of material from the exhaust ports. Port entrance shape/size remains identical to C heads so finding an intake isn’t hard. These heads are capable of producing power beyond 8000rpm, where earlier versions of the tumble port castings begin to lose their luster. FR500 heads are prone to the #6,7, and 8 cylinder cooling problems as well. Major intake port differences between these and earlier tumble port heads include a raised intake port roof, and a real short turn radius that better directs the incoming air into the combustion chamber; not over the valves like in earlier versions of tumble port heads. These heads also feature a dry divider in the exhaust port, which allows for greater flow, but also higher temperatures. Though improved, the heads can still use some TLC from a quality porter to smooth the roughly finished and newly implemented short turn radius, and the standard exhaust treatment.
The Bottom Line: Outstanding performance heads, with exceptional low and mid lift flow capability. The FR500s only real fault is that the newer ’03 DOHC heads provide near identical performance capability (much better on the exhaust side) paired with a cost differential that is approximately two-thirds less than the FRPP castings. Still a great choice for any application, the heads readily pair to a wide variety of stock and aftermarket intakes.
FR500 head dimensions: Combustion Chamber: 53cc, Intake Port Vol.: 160cc, Intake Port Entrance: 1.960”x1.350”, Valves: 37mm Int., 30mm Exh.
‘03 DOHC head: (‘03+ Aviator, Marauder, Cobra, Mach 1, Australian Boss 260/290)
Featuring a nearly identical (though 17cc larger in volume due to the fact that they are also used on the much larger Australian Boss 260/290 5.4L DOHCs) intake port to the FR500 head, but combining it with a newly designed, larger and more rectangular exhaust port, these may be the best all around DOHC Ford heads ever manufactured. The improvements made to the intake port shape over previous years include a raised port roof and the introduction of a short radius turn in the throat of the intake port that helps assure the incoming air charge finds the combustion chamber. For those with a forced induction street/strip motor, these are without question the best heads available, and as with the FR500s, they should produce great power up to and beyond 8000rpm regardless of application. ’03 DOHC heads also feature higher quality head castings from the supplier, which is at least partially responsible for the modest increase in flow vs. earlier castings--chalk that up to Ford’s revised quality control standards.
Early runs of the ’03 DOHC head fell victim to the same #6,7,8 cylinder coolant flow problems as earlier tumble port castings. In mid ’03 Ford made a running revision to the ’03 DOHC heads that allowed for more coolant to circulate through the affected areas. A blue mark on the driver’s side head indicates an updated casting, and there are no additional revisions to the ’04 version of this design.
The Bottom Line: On all accounts these are the best modular four valve heads currently available. They combine the exceptional flow of a slightly larger FR500 intake port with a gigantic new rectangular exhaust port.
’03 DOHC head dimensions: Combustion Chamber: 52cc, Intake Port Vol.: 177cc, Intake Port Entrance: 1.960”x1.350”, Valves: 37mm Int., 30mm Exh.
In Conclusion
Our panel of experts surmised that aside from the nearly unobtainable ‘00R heads, the ’03 DOHC heads are without question the right choice for your Modular four-valve performance application . The combination of a slightly larger FR500 intake port and modified throat region, coupled with a new larger rectangular exhaust port, and a relatively low price (due to it’s widespread use in the Ford organization) makes the ’03 DOHC casting the current head stud of Ford’s Modular stable.
After porting, the relatively small stock valves/seats become the most serious flow limitation; as such aftermarket replacements should be a serious consideration for those looking to squeeze every last drop of performance from their DOHC heads.
4V Heads
Ford has quite a few more 4V heads than 2V heads. The first type of heads are called “B” heads. These are found in the 1996-1998 Cobras and 1993-1998 Mark VIIIs. These heads are also known as swirl heads. The “B” heads have two intake valves as well as two exhaust valves. These heads flow 230 cfm at .500 inches of lift on the intake side and 145 cfm at .500'' lift on the exhaust side. There is a very unique item to the “B” style heads known as IMRCs or Intake Manifold Runner Controls. The IMRC is a computer that keeps the secondary intake valves closed until 3250 RPMs. In 1996 and 1997, they were made with aluminum and got very dirty. In 1998, Ford changed to a plastic style IMRC valves. Ford has this actuator to maintain torque down low and have good horsepower in the upper end. The heads flow too big for normal street use, hence the reason why Ford chose the IMRCs for these heads. The IMRC controller has been known to fail as well, causing a huge loss of power. Some people will go as far as deleting the IMRCs with a kit, but this causes bucking, stuttering and a loss of torque; I personally do not recommend this, even on a non N/A car. Eric Duncan has done some tests on IMRCs and found you can actually gain quite a bit of rwtq by having the valves open closer to 4000 RPMs than 3250 RPMs.
From 1999 to 2004, Ford switched to the tumble port heads. The tumble port style is meant to prevent condensation on the intake ports from dropping into the cylinder bore, as well as having a homogenous mixture for a more controlled, predictable burn. These heads flow better than the “B” style heads until .450 inches of lift; then the “B” heads take over. The 1999/2001 heads flow 225 cfm on the intake side and 145 cfm on the exhaust side at .500’’ lift.
Ford Racing came out with FR500 heads. These heads are another version of the tumble port heads. The heads outflow the 1999/2001 Cobra heads by quite a bit with 228 cfm on the intake side and 162 cfm on the exhaust side at .500’’ lift. These heads have quite a bit of meat of them to port but I personally do not recommend these anymore. Ford came out with even better heads, IMO. Expect to pay around $700 per head for these “jems.”
In 2003 and up to 2004, Ford developed what is probably the best “bang for the buck” head for the 4V motors. These heads are found on 2003-2004 Cobras, Mach 1s, Aviators and Marauders. The heads are still tumble port heads but much improved compared to the other years. The exhaust port is squared off at the corners, which is probably the easiest way of telling these heads apart from the other heads. Ford decided to use dedicated left and right castings for these heads as well which help keep cylinders 6,7 and 8 a little bit cooler. These heads flow 233 cfm on the intake side and 168 cfm on the exhaust side at .500 of lift. The FR500 heads do outflow these from .250’’ lift and below but the price more than makes up for them. You can find these heads for as low as $450 for BOTH heads.
Head Specs:
1996-1998 “B” heads:
Combustion Chamber – 52cc
Intake port – 107cc primary/115cc secondary
1999/2001 Tumble Port heads:
Combustion Chamber – 54cc
Intake port – 177cc
2003 Cobra Tumble Port heads:
Intake port – 177cc
FR500 Tumble Port heads:
Combustion Chamber – 53cc
Intake port – 160cc
Discussion Starter #17
I believe I may have found the 'Revised' Heads part numbers. Correct me if I am wrong:
Left side head
Part # 2C5Z-6049-BAB
Right side head
Part # 2C5Z-6049-CAB
I was referring to the difference in the style/shape of the intake port. Again, ALL 93-98 4.6 four valve heads are B-heads. B-heads have two intake ports per cylinder.
ALL 99-up 4.6 four valve heads are C-heads. C-heads have a single intake port per cylinder. This is true no matter the year, style, model, revision, etc... They are all C-heads starting in 99.
Discussion Starter #20
I am finding (from Ford) that the revised C heads are stamped with the engineering number 2C5E-6C064-DC but may also fall under the Ford part numbers listed above. I am also finding (via Ford) that the final revision on these heads occurred in 2005 so no cars received them during production.
I am doing my best to get with contacts the Dearborn facility to see what I can score at a reasonable price...........that fits these numbers.
1 - 20 of 41 Posts
