hey guys,
in the market for some caster camber plates as i have coil overs. but noticed that the paint shop painted around the stock caster camber plates. car is silver and im sure it is black under the stock plates.
is there a set of caster camber plates i can buy that will be larger than stock so you cant see this?
I don't think that's how I would decide which brand CC plates to buy. Buy the black MM 4 bolt plates and don't worry about it or spray can the top of the strut tower before you put the new plates on. I suspect the lack of overlap, if any, will be minimal.
