1 - 8 of 8 Posts
Alright so I just bought this kit and I am wondering what else I need.
I have a 70mm tb
73 maf
30lb injectors
Stock fuel pump with vortech t rex out tank fuel pump
Ported gt40p heads
Pro products upper and lower manifold
Biggest cam ford makes I think the z or x whatever is bigger
1.7 r.r.
Long tube bbk headers
Off road X pipe
Mac cats
Stock rear gears
Stock fuel rail
Holly adj. Fuel reg
Msd 6al
Msd coil
So what do I need and what do I need to upgrade? Thanks
I would switch that cam out for a custom cam or the f-303 or something like that.
At least 42# injectors
maybe a 255 in tank - not sure how that external will pull through a OE pump...
Engine management system or some sort of tuning device.
Sell your headers, exhaust, cam, and injectors. A stock cam would be preferable to an X or Z cam.
I have this kit!you will need at least 42lb injectors and a protube! i would put a 255 intank and the external pump right inline! with this you can ditch the fmu to 12-14lbs with the engine setup,i would however make sure to get a good TUNE! the X 303 however it has a 107/117 it probably will work but i would get a custom cam or f-303, i run the stock cam and it works great imade 535rwhp 622 tq,with dart sr iron heads 1.72 rrand a gt-40 @15lbs,and no fmu!as for the rear gears i would upgrade to 3.27 sounds great and happy boosting:leghump:
alright. i bought the kit from jeremy_wig on corral search for him on here. hopefully this kit is badass other wise im S*** out of luck.
How much would tuning be?
and how did the set up go with your cartech turbo??? fit good? all that good stuff.
thanks for the input and keep it coming!
1 - 8 of 8 Posts
